Water pipe leak o ring
Old Aug 3, 2021 | 08:31 AM
Spikepaga's Avatar
Default Water pipe leak o ring
Hi gents.
I am having, presumably, the same issue as here:
https://www.jaguarforums.com/forum/x-type-x400-14/04-3-0-coolant-leak-left-side-engine-between-cyl-banks-46404/
I want to replace the offending o-ring myself, but i can’t figure out which one it is in the diagram. Any help greatly appreciated. I think it might be ring number “2” but I am. It sure. Please take a look :
Old Aug 3, 2021 | 07:07 PM
watto700's Avatar
G'day Spike,
In your diag the part labelled #1 does not fit into the part labelled #7, this part does, P/N C2S16877, (see pic below) and it doesn't appear on the parts diag, which is odd.
Stop press! I found it and the 'O' ring here https://parts.jaguarlandroverclassic.../brand/jaguar/
The fitting in my pic is #1 and the 'O' ring is #18
Mine leaked so I undid the one bolt at the top and replaced the 'O' ring with one from a spares kit I had, it was a generic 'O' ring and not Jag specific. I did this repair several years ago and it hasn't leaked since.
The local Jag steelership wanted over $350.00 to fix it and I reckon it cost me less than a dollar to fix it myself.
Cheers,
Jeff.
Old Aug 3, 2021 | 07:55 PM
Dell Gailey's Avatar
O ring size is #17
Post 5 & 7 =
https://www.jaguarforums.com/forum/x...engine-217754/
Old Aug 3, 2021 | 08:39 PM
Spikepaga's Avatar
Thank you for your replies. I found all the o-rings in the area, but I am not entirely sure which one is leaking though. @Dell Gailey , I am assuming 18 is the one that was leaking?
I ordered 8,9 and 18
8= XR85353
9=XR85356
18=C2S22458
Is it necessary to drain the coolant as indicated in the other topics?
thanks!!
Joeybjr
Jun 17, 2023 05:59 PM
kenc
Sep 10, 2022 10:52 PM
chris tian
Jan 19, 2019 10:26 AM
rifziyad
Mar 8, 2018 06:08 AM
bezzy
Diesel variants - All models
Apr 7, 2016 07:40 AM
