Water pump tensioner wheel replacement
Old Apr 7, 2014 | 02:24 PM
Mr rx-7 tt's Avatar
Default Water pump tensioner wheel replacement
Hi,
I'm new here. I have a 2003 X-type with 55,000 miles. The water pump was leaking so I replaced it but noticed the bearing on the tensioner wheel is going bad. Can the wheel be purchased separate as the dealer and after market sources seem to want to replace the entire tensioner?
Thanks, Chris
Old Apr 7, 2014 | 03:49 PM
Brutal's Avatar
its one assembly as are most tensioners for most manufacturers now. reason: is pulley is going bad so too is the spring tension in the tensioner
Old Apr 7, 2014 | 05:41 PM
AlfaVeloce's Avatar
I tried replacing the bearing in one, but you'll end up breaking the wheel. It was an experiment that didn't work out. They're not that expensive. Just replace it.
Old Apr 9, 2014 | 01:09 AM
Mr rx-7 tt's Avatar
I guess I'll just buy a new tensioner.
Old Apr 9, 2014 | 01:11 AM
Mr rx-7 tt's Avatar
Also notice the power steering pump seems to have a slight leak, looks like a line. That's next.
Old Apr 12, 2014 | 06:55 PM
jimlaman's Avatar
Default speaking from experience...
My 2003 3.0 had the tensioner bearing seize recently, but daughter was driving it so.... it overheated, which led to cracked upper radiator "pipe", a job which I am in the middle of, and its a nasty one. Replacing the tensioner (I was not able to find a pulley either) was a piece of cake compared to this nightmare.
xjrjag
May 21, 2026 09:05 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Xj812
Oct 26, 2015 05:04 AM
celticpiping
Sep 18, 2015 06:17 PM
