weird ash tray question...
Old Jan 14, 2008 | 01:18 AM
jvegas's Avatar
Default weird ash tray question...
This is my first post! I got a 2003 X-Type about 2 months ago and love the car. I have a weird question, I noticed that the ash tray in the front does not have any kind of light in or on it so you can see in it at night. Is there a light there and my buld or fuse is bad? Thanks in advance for your help.
Old Jan 14, 2008 | 01:38 AM
SpartanX's Avatar
Default RE: weird ash tray question...
Nope, not just you. There's no light there.
Old Jan 14, 2008 | 09:34 AM
jvegas's Avatar
well that's not very Jaguarishness...
Old Jan 14, 2008 | 10:20 PM
JP10501's Avatar
haha, notjaguarishness at all ...
Old Jan 14, 2008 | 10:36 PM
jvegas's Avatar
Ok, don't get me wrong... I love my X-type. It may be one of the best cars I have ever had... But, with all it does and as much thought that went into it's great design you kind of wonder how such a common thing could be over looked! oh well, I hope the next Jag has a light where a light should be.
Old Jan 14, 2008 | 11:02 PM
GMAN04X's Avatar
There is that small amber light on the overhead console that lights up the whole lower console. Maybe they thought that was enough?
Old Jan 15, 2008 | 12:27 AM
jvegas's Avatar
is there any way to make that light brighter? besides the switch on the dash?
Old Jan 15, 2008 | 06:06 PM
SpartanX's Avatar
ORIGINAL: bojangles
Funny.. i have always wondered why there is a light at all in any ash tray? what on earth do you need a light there for?
+1 I see no reason to have a light there. Hell why would you smoke in a car, with leather?!?!?!
Old Jan 17, 2008 | 04:10 PM
jvegas's Avatar
I don't smoke in the car at all, but i keep change in there and it would be nice to see the change at night when I need too...
Old Jan 17, 2008 | 07:23 PM
aquill1's Avatar
ORIGINAL: jvegas
Well I guess you answered the question...its an ash tray not a coin tray! J/K
But whatever you actually need to see like say the cigarette plug has a light ring around it.
I'm going to dub it the "mood light" doesn't change with the knob last I checked...I wouldn't want that light any brighter...you could always hit the bright light on the upper console to turn on those lights so you could see the change...you could also wire a led in that area but the problem you will run into is that you'd have to put it on the side on inside of that area make sure the door doesn't open up and in and than cover th light! Know what I'm saying?
Old Jan 18, 2008 | 11:04 PM
jvegas's Avatar
Thats weird.. the "ring" does not light up at all! Where is the light bulb for that ring? does it have a fuse? remember that the lighter works but not the light. Thanks for any help!
Old Jan 19, 2008 | 12:02 AM
aquill1's Avatar
Pull her out and check her out! I'll have to pull mine out, perhaps tomorrow! On my way to NAIAS 08'
Old Jan 19, 2008 | 04:47 PM
aquill1's Avatar
Sorry I didn't take mine apart I had to drive and couldn't get a chance to tear it apart...
Old Jan 19, 2008 | 04:52 PM
jvegas's Avatar
if and when you get it out please let us know where the light is and how to remove then replace the whole ash tray assembly. Thanks!
Old Jan 19, 2008 | 07:30 PM
aquill1's Avatar
I will but it'll have to be warmer or have the heat on in the car because it is FREEZING HERE! I will do that for you asap though...its really easy to remove the ash tray compartment area...just give it a try...
Old Jan 27, 2008 | 12:24 AM
jvegas's Avatar
aquill, did you remove the ashtray yet? if so how did you do so? any pics of you doing it?
Old Jan 27, 2008 | 11:00 AM
310jag's Avatar
ORIGINAL: jvegas
No, Jaguarishness would call for there indeed to be a bulb, but for the bulb/housing to come loose from it's mount, drop into the ashtray, somehow make contact with some loose change, cause a short, blow a fuse which will somehow cause the dome light to stay on, in turn draining the battery and leaving the owners puzzeled as to what the phantom drain on the battery is! [sm=insomnia.gif]
If you think this is far-fetched, look into the power antenna/freezing water issues in in the Series III XJs.
