What size socket for rear hub nut?
Old Sep 10, 2015 | 10:45 AM
iownme's Avatar
Default What size socket for rear hub nut?
About to replace a rear wheel hub and bearing and need to know what size socket for the hub nut.
Also anyone know torque specs for hubnut and the hub bolts?
Old Sep 10, 2015 | 03:13 PM
dwclapp's Avatar
iownme: You'll need a 32mm socket. A good impact wrench makes the job much easier. The part number for the replacement nut is C2S46889 - you're not supposed to reuse the old one. I got them for ~$12 each on eBay. Tighten to 270 Nm / 200 ft lbs.
Good luck.
Old Sep 11, 2015 | 02:57 AM
iownme's Avatar
Good luck.
Thankyou :@)
Forcedair1
Sep 8, 2025 01:57 PM
jagent
Sep 12, 2015 01:40 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Joey T
Sep 3, 2015 05:31 PM
innzane
Sep 2, 2015 10:08 AM
