Wheel Bearing Diagnose
Old Dec 11, 2025 | 02:30 PM
Larry-Cleveland's Avatar
Default Wheel Bearing Diagnose
Hi Guys,
It sounds like it is a wheel bearing time. I forget which side the problem is on, but when I turn hard to the left, the sound goes away. Loading and unloading. LEFT or RIGHT???
Merry Christmas
Old Dec 11, 2025 | 03:19 PM
Jagboi64's Avatar
If you turn to the left, that should load up the right side of the car. If the sound gets quieter, than that sounds like a left side bearing.
Old Dec 11, 2025 | 03:50 PM
Hmmmm, A hard left would make the left side of the body go down and the right side go up. Would it load the left side more?
Old Dec 11, 2025 | 04:57 PM
Jagboi64's Avatar
Other way around, the body always rolls to the outside of the curve, and the inside lifts. So turning left, the weight shifts to the right side of the car.
Old Dec 14, 2025 | 12:23 AM
95naSTA's Avatar
The best thing to do it get each corner in the air and pull on the wheel to check for play.
In my experience, applying the brakes quiets a bad bearing. The caliper is attached inboard of the bearing and takes some of the pressure off. A bad bearing will also accelerate wear on the inside pad on a normal sliding caliper setup.
Kuddlesworth
Apr 2, 2022 12:11 PM
Dmcr
Dec 15, 2021 03:29 AM
Jagm1979
Aug 28, 2014 09:51 PM
