Wheel bearing replacement, OE with Timken?
Old Nov 3, 2011 | 05:30 AM
KaysKat's Avatar
Default Wheel bearing replacement, OE with Timken?
So I pulled the knuckles off my 04' and picked up the timken replacement bearings. My Jag mechanic points out that the timken doesn't have one side with a plastic dust cover that typically the OE bearing has which covers the exciter ring for the ABS sensor. This timken part (510029) is what all the part suppliers list as the replacement. Also, the bearing in the timken box, was a SKF bearing. The existing bearings in the knuckles are SKF bearings, but different part numbers! Don't want to go through all this to get an ABS fault! Anyone care to chime in???
Old Nov 3, 2011 | 11:57 AM
rarebell's Avatar
Buy the SKF Bearing they are only $9 more for each one
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
JaguarXKR
Sep 6, 2015 11:47 AM
Bcrary3
Sep 3, 2015 10:54 AM
TC Johnson
Aug 29, 2015 08:55 PM
