Wheel order for brake fluid rep?
Old Aug 6, 2011 | 08:24 AM
billrata's Avatar
Default Wheel order for brake fluid rep?
What is the wheel bleed order for brake fluid replacement?
Also, thanks for all the quick, accurate responses to my previous questions. This is a great site, at least for me.
Bill
Old Aug 6, 2011 | 08:40 AM
I don't think it is critical as there are separate lines to each, but traditional procedure is passenger rear, driver rear, passenger front, driver front, bleeding the furthest away line first.
Old Aug 6, 2011 | 08:41 AM
billrata's Avatar
Thanks Norri
Bill
Old Aug 6, 2011 | 09:11 AM
Bill,
Also a good idea to remove the old fluid from the reservoir before you begin with a syringe or similar and replace with new so that you start flushing new fluid down the lines from the start.
Old Aug 8, 2011 | 07:14 AM
The Chris X's Avatar
Norri is spot on like usual.
When removing the old fluid, just be careful not to completely drain the reservoir or you end up pushing air through the system. So take most of it out with a fluid transfer device or turkey baster, then add new fluid to the little bit of old fluid. Frequently check the level in the reservoir as you go to make sure it is topped up while bleeding. Once you get clear clean fluid and no bubbles at the first wheel, move to the second and so on.
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
Doug
Feb 27, 2019 01:31 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Holden
Sep 5, 2015 03:29 AM
