Where is the central console?
Old Apr 1, 2017 | 09:19 PM
Harry Peter Rose's Avatar
Default Where is the central console?
JAGUAR X SERIES DSC could be disabled with a switch on the centre console cannot even find the switch! WHERE IS THE CENTRAL CONSOLE?
Old Apr 2, 2017 | 12:35 AM
sov211's Avatar
Assuming that this is a serious question, the centre console is the unit between the two front seats. The DSC button (if the car is so equipped - not every X-Type is) is found to the right and forward of the emergency brake handle. Cars that do not have the DSC have a coin slot /lock light unit there.
Old Apr 2, 2017 | 02:07 AM
nothing other than the............ SPORTS MODE BUTTON
Old Apr 2, 2017 | 11:38 AM
sov211's Avatar
You are looking in the wrong spot. Find the centre armrest. Now look forward and down. You will see a small insert in the console which has a red light at the forward edge and the major part of this insert will have a grille form (it is not a grille - those are coin slots) OR if the car is fitted with DSC, you will find a button for disengaging the DSC.
Old Apr 2, 2017 | 01:07 PM
think only a "coin slot?"....
where would the actual switch be located if DSC is installed?
thanks guys!
Old Apr 2, 2017 | 06:54 PM
think only a "coin slot?".... plus THE RED LIGHT ON PART OF "THE COIN SLOT"............
I am sure is alarm on indicator.....not DSC?
thanks guys!
Old Apr 3, 2017 | 01:01 AM
have that.....red light is alarm correct?....still attempting to locate switch for
DSC..if installed?
Old Apr 3, 2017 | 08:48 AM
Alfadude's Avatar
You EITHER have the coin slots if you DO NOT have DSC OR if you have DSC the switch would be located where the coin slots are. You would NOT have both. There is NO hidden switch. Here is what the switch would look like if you have DSC which you do not.
Old Apr 3, 2017 | 11:52 AM
Finally a clear and precise explanation!.....
.many thanks
Old Apr 3, 2017 | 12:21 PM
yardbird's Avatar
ok.... here's a dumb question.... so maybe I'm JUST the guy to ask it....
If my VDP doesn't have DSC (I have the coin slots).... is everything in the car FOR that feature to be enabled? I mean.... is there wiring for the DSC switch under the center console and you just have to enable it in one of the many onboard computers?
I know in a lot of cars, they build them the same (cause it's cheaper) and just don't install the access to certain features listed as optional.
