Why do my gauges on a dashboard vibrate
Old Jan 7, 2015 | 02:10 PM
draganapiazzola's Avatar
Default Why do my gauges on a dashboard vibrate
I have a question. This only started happening this morning. When i start the car, all the gauges on a dashboard kind of vibrate for a second or two and then stop. Never had this happen before on any vehicle i owned so i am not sure what the issue is. Can anyone relate? This is on my 2005 X Type 3.0
Old Jan 7, 2015 | 02:28 PM
WhiteXKR's Avatar
The gauges on your car are actually stepper motors. The movement is calibrated each time the battery is re-connected and the the movement parameters are stored in computer memory. This process takes 1-2 seconds and causes the needle to vibrate against the stop.
If this just happened randomly, it is probably because the battery voltage went unusually low this morning when you started the car (was it very cold out?) and caused the instrument cluster to reset, or the instrument cluster detected an internal fault of some sort and reset itself.
It might be worth having the battery checked...it could be an early sign of battery failure.
Old Jan 16, 2015 | 04:49 PM
I had replaced the battery and no issues since. I was surprised that the battery just went dead the next morning. It wouldn't take the jump either. New battery is working great so far
JaguarLover101
48
Jun 12, 2023 10:28 AM
workworkwork
Oct 23, 2015 10:26 AM
carl purchase
Oct 14, 2015 06:14 PM
vwbusbits
Oct 13, 2015 03:43 AM
