Window issue
Old May 3, 2013 | 09:51 AM
lucasfreight's Avatar
Default Window issue
Hi - new here and a new jag owner
sneaked out of work to try a fix i saw on your forum but it didn't work - ie holding the switch all the way up for a few seconds and then all the way down, i assume to reset the parameters? see below...
have a 2001 sport 2.5 and the drivers side (incl pax) has a strange issue with opening and closing the windows...
to open it takes three/four pushes as its stops every few inches, then to close them every 8th pull of the switch the window goes up and can take 4/5 times to completely close...
ideas anyone please?
Old May 5, 2013 | 05:16 PM
UKSkidMark's Avatar
In theory the motor stops when it meets resistance. Have you tried some silicon spray in the window guides to help it glide?
Old May 6, 2013 | 02:13 AM
Thanks Skid Mark... I'll certainly give it a go As it has been stood for a while... I'll let you know!
Old May 6, 2013 | 11:35 AM
sadly it wasn't a lubrication issue... its very strange as it goes down to the same level each time and takes 4 pushes to completely open, then to go up, to make it move anywhere it takes 8 pulls on the switch (moves on the 8th but only partially) then another 8, and up a bit more etc... howevere if you only close a very little it will go up in very short closes without having to pull it back 8 times again....
i think it might be a programming issue rather than the switch now, i don't think it would be so consistent if it was the switch....
is there any way of plugging her in to a laptop or is that strictly reserved for the garages with the right software?
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
GordoCatCar
Jan 2, 2017 01:10 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
