Windshield Washer Jet problem (Broken)
Old May 10, 2011 | 10:04 PM
TJ_xtpe's Avatar
Originally Posted by CatFan
I've had both jets go bad over the last few years. They get brittle and fall apart.
They cost $28.95 each at Auto Parts Warehouse. Part number: W0133-1657781
Any other part of the washer hose line you can find parts for at your local auto supply store for a few bucks.
My left jet (driver side) just recently broke. The hose is fine but i believe the nozzle of the jet broke off inside the elbow type hose. Is the jet easy to replace? Is it as simple as pulling off of the hood and replacing? I dont want to remove the wrong thing. Your help is greatly appreciated.
TJ
Old May 11, 2011 | 08:51 AM
Adam Lueb's Avatar
If you mean the black plastic squirter on the hood, they disconnect underneath, usually there are two tabs you press together and they pop out. Take the hose off first. You might need a plastic panel tool, as some of these squirters are pressed fit and you will need to pry it out from underneath.
Old May 11, 2011 | 06:38 PM
disguay's Avatar
Originally Posted by Adam Lueb
I had the left washer not working, I took a pin and cleaned out the opening and around the opening, works fine now
Amen to this fix. Worked on my saturn awhile ago. I used a toothpick though just to make sure the pin didn't go through the plastic.
Old May 12, 2011 | 07:27 AM
SirJag's Avatar
Need to clarify. The part in question is the SPRAYER JET... this is a little black device that rides on the wiper blade. SCREENWASH JET It has a few little rubber tabs. Seems like one of them is torn and water is spraying mindlessly from it, I believe. It moves too quickly to really see what's happening. It's beyond the pin technique, unfortunately. I'll change it and report back on this.
SirJag
Old May 12, 2011 | 08:30 AM
yskw1024's Avatar
Finally i had replaced my old broken washer jets with third party jets, just found the biggest one, and it was working well. No more problem ; )
Old May 14, 2011 | 07:30 AM
Adam Lueb's Avatar
Smile Windshield squirt
SirJag
Best thing to do then is replace, Question why is the one on the link blue? Mine is black and so are most others. I do have chrome covers over them which are slick.
Old May 14, 2011 | 09:59 AM
Gold_04_X-Type's Avatar
SirJag
SirJag, You are talking about sprayer jets for an XJ8 in the X-Type forum, that is why you are causing confusion. The X-Type washer nozzles are mounted on the hood (bonnet).
Old May 15, 2011 | 06:06 AM
  #28
SirJag's Avatar
OOps... sorry.
Old Nov 27, 2015 | 07:40 AM
funmarcs's Avatar
Default washers fixed
My washers stopped working and found the tube which feeds both bonnet jets was trapped by the hinge, the test is if they spray fine with the bonnet up.
Old Jan 15, 2016 | 05:10 PM
  #30
RobinGa's Avatar
I have a broken nozzle jet on driver's side. The nipple that the supply hose fits on broke off inside hose end. I bought a new Jaguar nozzle jet part and cannot determine how to get the old one off the hood. I am afraid to use brute force for fear of breaking something else. Can anyone provide a description on how to take off a windscreen nozzle jet?
Old Jan 15, 2016 | 10:22 PM
  #31
mel.lugo's Avatar
Hi Rob
I have never removed the spray washers but I have this from anther member (Meatbag)
"Replacing therm took all of 3 minutes. I looked carefully at the new ones because you can't really see how the existing ones are attached up in that hole they are in on the underside of the
bonnett bonnett
. They have a stiffish plastic latch on the underside of the nozzle - on the end that points toward the front grill. I took a pair of pliers with rubber grips on the handles and stuck the handle end up in there like a lever to apply a bit of push onto that clip, and those little suckers popped right on outta there."
Hopefully that helps.
Old Jan 16, 2016 | 04:43 PM
  #32
RobinGa's Avatar
My original one was so brittle that as I was trying to pry, it kind of broke then fell out of the hole onto the windshield. So it came out not in fashion I expected but is out. I pulled out the broken nipple end that was still in hose. I installed my new jet in the hole in hood and connected hose. Then I tried it out and was disappointed that water didn't shoot out. So I checked my hose sections and there is a check valve in the hose between the two jets. That check valve is stopped up. I've tried small wire and some compressed air but it's stuck solid. I will try my auto parts store for one tomorrow. Thanks!
Old Jan 16, 2016 | 06:28 PM
  #33
RobinGa's Avatar
I had an inline coupler and not a check valve that I put in temporarily to test my new nozzle. It does work but the flow is weak. The other jet is extremely strong and in fact one of the water streams is high and goes over the length of entire car. It's as if the first jet is taking all the water pressure and not enough makes it to second jet. Anyone experience this and know a fix?
Old Jan 16, 2016 | 11:21 PM
  #34
wa3ra's Avatar
Had that problem; turned out a piece of plastic from the suicided T-connector was stuck in the tubing. Replaced all of the tubing, along with the brittle nozzles. Got the nozzles from a ford dealer, I believe they were for a '92 escort (just matched up the numbers)...$20 for the pair!
Old Jan 17, 2016 | 12:06 PM
  #35
RobinGa's Avatar
Success! Wa3ra gave me an idea and my theory worked. I had to scrape out remnants of the old broken jet nipple from tube end and I must not have gotten out each tiny piece. So when I hooked up my new one it seemed to have clogged the fine jet outlets. I removed both my jets from hood and all the tubing connected to them. Then with my compressed air I blew everything out from reverse flow direction. There were some fine particles that blasted into my hand from the new jet. I blew out the tubing and both jets again for good measure. Hooked it all back up and it now works perfectly! Thanks for the inspiration
Old Mar 25, 2016 | 10:56 PM
  #36
dougie's Avatar
usually when washers go its the pump filter blocked in bottom of washer bottle, remove bottom access panel in front of wheel, pull out pump with hose attached ,pull of gauze filter, clean out under running water,reassemble , but leave access panel of till tested.
al_roethlisberger
Sep 11, 2015 10:04 PM
Tar
Sep 6, 2015 11:24 AM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
