Wobbling X-type
Old Jan 24, 2008 | 02:43 PM
Dennis's Avatar
ud
Default RE: Wobbling X-type
Sounds like maybe a tire problem... or bent wheel
Old Jan 24, 2008 | 08:32 PM
jvegas's Avatar
check that the lug nuts are tight. it sounds like that might be it.
Old Jan 24, 2008 | 09:20 PM
Dennis's Avatar
ud
God! that might be it..I didn't think of that, but now that you mentioned it, I've heard of people in my past telling me they felt simular wavey motion/feel with the car a few days before one of their wheels came off....Check it out soon.
Old Jan 24, 2008 | 09:23 PM
FactoryJaguarTech's Avatar
Also bear in mind, the X-type wheel bearings often do not make noise when they are bad.
Definitly do not drive it around until you figure out what it is.
Old Jan 24, 2008 | 10:25 PM
aquill1's Avatar
My monte carlo didn't make a wobble before they fell off! Or actually broke/fell off. Did it recently snow where your at? I know at times snow gets lodged on the lip of my rims and makes a terrible wobble...sorry if that didn't help...
Old Jan 25, 2008 | 10:00 AM
jvegas's Avatar
good point aguill. it might be snow or ice on the rim or tire. I have always found that when something strange like this happens it can;t hurt to run the car through the car wash. perhaps the snow, ice, or dirt that is making this happing will be washed away. in any case please update us and let us know what it is. A quick way to check if it is the lug nuts is to put your foot on the tire and push on it hard. if it moves then there you go.
Old Jan 25, 2008 | 10:04 AM
jvegas's Avatar
I just thought of something else! Does the car have directional tires? make sure the are "going the correct way"
Old Jan 25, 2008 | 10:05 AM
H20boy's Avatar
Sway bar? just tossing out ideas.
Old Jan 25, 2008 | 11:57 AM
aquill1's Avatar
I don't know if it'd be sway bar...I had a bad link or something of that nature and the car somewhat had a minor shake and it wasn't fixed...I think my case might just be roads though as most of the time it doesn't do it....the 225 tires suck for bad roads...not to mention I need to get some new tires...sucky part is it could be any of the things listed here! Hey menno have you guys noticed any irregular wear of the tires??? A bad alignment could cause a shake could it not?
Old Jan 27, 2008 | 11:32 AM
jvegas's Avatar
damn! I thought i got this one right! what about the directional tires?
Old Jan 27, 2008 | 09:49 PM
jasonzimbran's Avatar
Hey guys I was driving a few days ago and I was getting on the ramp to get on to the highway I was about 40mpg and taking a curve and it started vibrating alot and then it stopped after I got off the corner?
Old Jan 27, 2008 | 10:42 PM
jvegas's Avatar
sounds like it was the road. drive that same ramp in the smae weather and see if it does it again.
Old Jan 28, 2008 | 01:29 AM
wanganracerx's Avatar
Check your tire presure. I had the same problem, turns out my tire presure was all wacked out. hope this helps.
Poet
Feb 7, 2025 02:18 PM
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
millertic
Sep 30, 2015 08:11 PM
