Wrong fuel type causing check engine?
Old Jun 21, 2012 | 09:28 PM
louiloui's Avatar
Default Wrong fuel type causing check engine?
I've had no problems with my car and have even had my mechanic check it out within the last 6 months. A friend of mine recently told me that it was okay to use medium grade gasoline rather than premium unleaded (as it says by the gas gauge).
Could this be the cause for my check engine light? Using the lower grade gasoline?
Thanks.
Old Jun 21, 2012 | 09:54 PM
PreJag's Avatar
I've been using regular for over a year with no problems. I don't think the grade of fuel could cause a 'check engine' light, unless you have a faulty, or overly sensitive knock sensor. You need to have the codes scanned - this will tell you what's causing the MIL light. Good luck.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
ControlIssues
Sep 3, 2015 07:38 PM
Drew2006
Aug 28, 2015 04:22 PM
