X-Type 04 remote unlocks the door but doesn't lock
Old Dec 14, 2014 | 08:07 PM
detonator's Avatar
Default X-Type 04 remote unlocks the door but doesn't lock
I got this weird problem on my car.
When I press the remote key to unlock the car, it unlocks without problems. But when I press the red button to lock it, nothing happens.
I can, of course, lock the doors manually so it's nothing too urgent.
I only have one key left so I can't test it with the spare key.
Could this be an indicator of key battery power (too low)?
Thanks in advance.
Old Dec 18, 2014 | 10:20 AM
Scricy's Avatar
try changing the battery of the key. i remember mine had similar problems when the battery was almost dead.
also after you change the battery, you will need to reprogram the key.
Good luck!
Old Dec 18, 2014 | 11:28 AM
Schlim's Avatar
I changed my battery and didn't have to reprogram. But yes, battery is the likely solution. Less than $10 at CVS.
Old Dec 18, 2014 | 12:06 PM
sawduster's Avatar
I had this problem with another car I had and after taking apart the key fob I found there was a very tiny metal disc that acted as a spring against a contact below it. I think the piece either broke or became dislodged, so the button simply did not work. I managed to get it working by somehow taping it together, but it was dicey. I immediately sold the car before it broke again or the tape let loose.
I'm not suggesting you sell your car due to a bad keyfob button, but if that is your problem then then you would need to replace the keyfob. And if you can hold off until 2016, you could sell your x-type and buy a new XE.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Bigvettefreak
Sep 6, 2015 04:27 PM
