X Type 2.1 V6 Battery Light On...Alternator or Faulty Cabling?
Old May 12, 2016 | 03:17 AM
xtype62's Avatar
Default X Type 2.1 V6 Battery Light On...Alternator or Faulty Cabling?
Hi! Used engineering test(found on this site)showed voltage reading of 11.2-11.8,battery light mostly on Is this more likely to be pos cable resistance or alternator fault? Just in case,what has to be removed to extract alternator on V6 2.1 manual model? Thank-you....
Old May 12, 2016 | 08:29 AM
DPK's Avatar
DPK
More than likely the problems with low voltage is bad cables...I would replace ALL the Battery cables first....Mine was doing the same thing, until I replaced them and system returned to normal voltage levels.
Old May 12, 2016 | 08:34 AM
xtype62's Avatar
Default Alternator or faulty cabling?
Thanks DPK Where would I source new cables,and at what price? Rew
Old May 12, 2016 | 08:52 AM
avern1's Avatar
I had the same problem. You might want to try removing and cleaning the cable connectors to the battery first. I cleaned mine and replace the ground cable connector and no more problem. Might work for you too.
Old May 12, 2016 | 10:49 AM
DPK's Avatar
DPK
Good advice arvern...But to add..the problem is usually with the connecter making good connection to the cable..one can tell, if there is signs of heat stress and discoloration, along with insulation brittleness... I've seen here somewhere where folks removed the old cable ends and replaced it and that solved the problems as well..
xtype62
May 11, 2016 05:40 AM
bluebird
Sep 2, 2014 07:05 PM
Krp
Jun 27, 2013 11:48 AM
