x type 2002 broken dispstick handle
Old Mar 15, 2024 | 09:08 PM
mickvic's Avatar
Default x type 2002 broken dispstick handle
Broke the handle off my dip stick , engine oil. Does the dip stick tube come out of the engine block? Any other ideas to get it out and replace?
Old Mar 16, 2024 | 05:57 AM
Peter_of_Australia's Avatar
The dip stick is make from a ferrous material (I just went out to my X-Type and double checked). Hence, the obvious solution for you would be to use a magnet on a stick (those are available for purchase (cheap), with an extendable stick (like an antenna)) to pull the stick out with that magnet.
PS: ...if you cannot get it with small pliers or tweezers...
Last edited by Peter_of_Australia; Mar 16, 2024 at 06:42 AM. Reason: Added PS note
Old Mar 23, 2024 | 01:34 PM
dh53's Avatar
Part number for dipstick is C2S20878. I haven't tried it but it looks like you remove 1 bolt on the dipstick tube mount then simply pull and twist the tube off. Just an O-ring sealed slip fit into the engine.
https://www.sngbarratt.com/English(U...9-72c268025dda
Old Mar 24, 2024 | 05:23 AM
mickvic's Avatar
Thanks a lot yeah the magnet doesnt work
Old Mar 24, 2024 | 10:47 AM
Dell Gailey's Avatar
Undo 8 and pull out 7.
Iticip
Aug 2, 2022 07:44 AM
tinumon
Oct 26, 2017 02:52 AM
Simplemechanic
Nov 9, 2014 12:24 PM
PanamaJag
Jul 27, 2014 01:57 PM
