X Type 2003 2.5 P1647 read, whats this?
Old Aug 10, 2012 | 09:55 AM
Steve_Jaggar's Avatar
Default X Type 2003 2.5 P1647 read, whats this?
As above anyone Know this code and how to fix?
Regards
Steve
Old Aug 10, 2012 | 10:35 AM
Steve,
P1647 : ECU HO2 Sensor control malfunction - bank 2 upstream
Other than a circuit fault, I'd think it's likely to be a duff Sensor.
Old Aug 10, 2012 | 10:51 AM
Cheers mate I'm now looking at the connectors on the rear cat will the sensor just unscrew from the cat?? I might give it a clean. I hope im in the right place
cheers
Old Aug 10, 2012 | 11:01 AM
Steve,
The description 'just unscrew' hasn't applied to the last few Sensors I've removed. They were b****y tight!
Old Aug 10, 2012 | 11:37 AM
Yeah its s*ds law.....
There is two sensors on the front cat upper (grey plug & lower black plug. Is it the upper one that needs lookin at if cleaning terminals dont work.
Old Aug 10, 2012 | 12:07 PM
It will be.
If the X-Type is similar to the XJ and XK, the wires aren't set to a specific sensor. They are wired up first and then configured using the dealer WDS. Just in case, don't get them mixed up!
Old Aug 10, 2012 | 12:12 PM
both are colour coded so you cant get them mixed up. Its looking like a sensor problem cleaned terminals up re connected but the fault is still there
stanjag
Dec 29, 2024 08:26 PM
ClassiXtype
Oct 22, 2023 05:29 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
dcvickers
Sep 2, 2015 06:14 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
