X-Type front wheel bearings
Old Aug 31, 2021 | 11:14 PM
Engadian's Avatar
Default X-Type front wheel bearings
I recently replaced the front wheel bearings in my 2007 X -Type wagon. When I installed the whels I found that they would not turn because the disk was fouling the caliper carrier. Thinking I had done something wrong I removed the front left bearing. I also removed the large circlip for cleaning and noticed that just inboard from the circlip was a shoulder. So what is the purpose of the circlip. Without the circlip the new bearing would enter further and thus provide the bnecessary clearance between caliper carrier and disk. I cjhecked the dimensions of the recently removed bearing with the new one (SKF) and it was dimensionally identical. I carefully re-watched the U-Tube video and the mechanic said he was expecting to find a circlip on his car bur there was not one. Does anybody know whether Jaguar modified the desing to omit the circlip sometime in the X Type's history and is there any reason why I should not replace the bearings without a circlip? Any information would be appreciated
Engadian
Old Sep 1, 2021 | 05:56 AM
Thermo's Avatar
Veteran: Navy
Did you make sure to install the bearing in the correct orientation? That may be your issue. Otherwise, I would then have to say that the bearing was not seated fully.
Old Oct 2, 2021 | 05:07 AM
aidsmith's Avatar
My X type (2007) doesn’t have circlips on the front bearings.
Old Oct 2, 2021 | 11:26 AM
Engadian's Avatar
Thanks for the suggestion. The bearings were definitely installed in the correct orientation and fully seated. I have now re-installed new bearings without the circlip and all clearances are now perfect. But when and why did Jaguar stop installing circlips?
Old Oct 2, 2021 | 04:18 PM
Thermo's Avatar
Veteran: Navy
Engadian, I never replaced the front hubs on my X-Type. So, not sure when a change like that would have happened. I can see a need for them. Granted, with how they get pressed in, I can't imagine them falling out though either.
retroren
May 19, 2021 12:26 PM
Jagman99
Mar 6, 2014 07:34 PM
GordoCatCar
Jul 29, 2013 04:40 PM
2xlooser
Aug 18, 2011 08:20 AM
lovemycar1
Aug 4, 2011 07:28 PM
