X Type Hand Brake
Old Mar 22, 2020 | 09:22 AM
Ely Grys's Avatar
Default X Type Hand Brake
I have a problem that the hand brake lever ride too high and does not stop the vehicle from rolling on steep inclines.
We have replace the pads but no change.
it's a mechanical system (no electronics)
Would like to know a solution if possible.
We already checked the rear calipers and the piston is twisted out to just lightly touch the discs upon reassembly.
The calipers work smoothly and the pistons are clean.
Is there a way to check the hand brake mechanics in the calliper?
Please note that there's a lot of slack in the single cable going to the hand lever in the cockpit.
How could this slack be eliminated
Quote
Old Apr 1, 2020 | 03:02 PM
rapala's Avatar
If you have manual transmission there will be a cable adjusting mechanism under the car at the handbrake lever . However if you have auto transmission there is no cable adjuster at the hand brake lever. I don't know why that is though.
Old Apr 1, 2020 | 04:09 PM
Thermo's Avatar
Veteran: Navy
Ely Grus, the best advice that I can tell you is to first get the rear of the car in the air and pull both rear tires. Then, engage the e-brake. You should see the levers come a little forward and then stop. You can then attempt to move the tire by hand and see if the brake is engaging. If you are seeing both levers move the same amount (just a little bit), then your problem is a cable that has stretched over time and you need a new cable. If one lever goes way forward and the other barely moves, then one that moved has a bad caliper and it needs replaced or repaired. The other check you can do if you don't feel like pulling the tires is to engage the e-brake with the car jacked up some. You want to look at the bar that splits the e-brake cable from 1 cable to two. If the bar is straight across the car, then you have a cable problem. If you pull the lever and the bar moves to an angle, the side that is pointing towards the front tire is your problem side. Need to look at the caliper and figure out the issue.
dynajag02
Mar 22, 2020 07:38 PM
Fleet_Flyer
Jan 13, 2020 10:39 AM
jaglee74
Jul 25, 2017 03:36 PM
Eskr
Jul 23, 2017 01:23 AM
Roman K
Jan 29, 2013 05:13 AM
