X Type Jaguar Stop Light possible fault
Old Sep 5, 2015 | 09:46 AM
joseph1945's Avatar
Default X Type Jaguar Stop Light possible fault
Hi all, I have a 2003 X Type saloon 2.0D and when I push the clutch pedal right down the stop lights come on, has any one had this happen and is it supposed to happen if not can anyone throw some light as to why ????????
Old Sep 5, 2015 | 06:58 PM
hlgeorge's Avatar
Haven't heard of that, but sounds like a good safety feature.
Old Sep 5, 2015 | 07:12 PM
Thermo's Avatar
Veteran: Navy
Joseph, odds are, if you look under the dash near where the clutch pedal is (above the clutch pedal), odds are, you are going to find that either the linkage or other moving part of the clutch is coming in contact with a wire bundle and it just happens to be cutting on your brake lights. Should be a fairly easy fix. The trick will be finding the wire bundle. Getting your head under the dash can be a bit tricky. The easiest way I have found is to lay the seat all the way back and sit in the seat upside down (ie, head in the footwell, feet by the roof).
Wish you luck.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
Jandreu
Aug 29, 2015 07:31 PM
NinoGrimace
Aug 26, 2015 05:15 AM
