X-type Jerks and gives a thud when stepping off and on the gas.
Old 09-20-2011, 06:04 PM
edge1212's Avatar
Question X-type Jerks and gives a thud when stepping off and on the gas.
Hey Guys,
I have a 2004 X-type 3.0 Sport with 97k miles on it.
When i'm at speed, let off the gas, and re-apply it, the car gives a little thud from underneath along with a small jerk. I was wondering if it could be a broken motor mount possibly? Any Opinions?
Thanks!
Old 09-21-2011, 04:37 AM
barney100golf's Avatar
Sounds like a U J you need to check
Old 09-21-2011, 05:41 AM
When the car is stationary and the car is rocked backwards and forwards is the noise pronounced and can it be felt through the wheels. If it is not the U J it could be rear subframe mounts which are a known issue, they are located forward of the rear wheels and attach the subframe to the body with a large flat bush, this gives up and allows movement in the whole frame, replacement is relatively easy with the right tools.
edge1212 (09-26-2011)
Old 09-25-2011, 02:49 AM
edge1212's Avatar
Thanks for your suggestions guys, I took a look at those areas. Found that the driveshaft had a lot of slack in it. The U Joint connecting the two sections of driveshaft in the middle of the car is worn. Unfortunately the UJ is non-replaceable so looks like i'll need a new driveshaft. >_<
JaguarLover101
48
06-12-2023 10:28 AM
Paora
02-04-2021 12:36 AM
Msteiner
05-16-2016 12:19 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
10-05-2015 04:05 PM
millertic
09-30-2015 08:11 PM
Quick Reply: X-type Jerks and gives a thud when stepping off and on the gas.
