X-Type oil pan help...
Old Mar 16, 2018 | 01:08 PM
Julianj08's Avatar
Default X-Type oil pan help...
Trying to replace oil pan gasket on 05 x type.. got the bottom part of the oil plan detached from the upper part... I can not removal the bottom pan from the car... it seems to be wedged in by the car frame on one end and the transmission on the other end... what can i do???
Old Mar 16, 2018 | 01:11 PM
Welcome to the forum Julianj08,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Mar 16, 2018 | 02:34 PM
astromorg's Avatar
Using a jack under the gearbox, the engine mounts have enough 'give' to let you lift the engine just enough to get that extra bit of clearance. Some have also removed the oil pump pick up pipe, but it's not necessary and a bit of a fiddle when re-assembling.
Old Mar 16, 2018 | 02:47 PM
Julianj08's Avatar
Default Holy smokes... It worked
Did just what you said... the pan fell out of the car...THANKS!!!
Old Mar 17, 2018 | 02:40 AM
Julianj08's Avatar
hi astromorg... I saw your name in several places related to the transfer case... would greatly appreciate it you can walk me through reinstalling the transfer case... perhaps we can talk by phone and I will compensate you... please reach me at 404.277.2312
thanks
John
Old Mar 17, 2018 | 05:46 AM
astromorg's Avatar
Being in UK, that could be a costly phone call!
Check out your other thread about t'box replacement where I posted some links.
ghiadon
Oct 17, 2016 07:45 PM
gboy
Oct 14, 2016 12:34 AM
Ingo85
Oct 12, 2016 01:35 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
