X type passenger door
Old Jan 18, 2009 | 04:48 PM
gatsbys's Avatar
Default X type passenger door
I've just changed the front passenger door on my X (old one got damaged too much) and it doesn't respond to the remote or the key (in other words, it don't lock/unlock) but it does lock/unlock from the inside (and locks all the other doors when you use the handle).Does anyone have any ideas-is it some sort of solenoid or something?
PS....this is my first post!
Old Jan 18, 2009 | 07:22 PM
McJaguar's Avatar
Default RE: X type passenger door
welcome to the forum!
did you check the FAQ's ? I know there's on in there about removing the door panels. I haven't read it, but there might be some help there.
If not, holler back and we'll see what we can come up with.
Old Jan 18, 2009 | 07:52 PM
Brutal's Avatar
take out the door module from your old door and put it in the new 1, if you dont have it anylonger youll need to have it programmed at the dealer
Old Jan 19, 2009 | 01:21 PM
gatsbys's Avatar
Thanks guys-I've still got the old door-would the module be where thelong metal wire (which eventually attatches to the door opener) goes to the left of the door as you look at it? I think its called the actuator?
Old Jan 19, 2009 | 03:25 PM
McJaguar's Avatar
ORIGINAL: McJaguar
wow. I totally misread your post!
I didn;t realize you replaced the entire DOOR!
Sorry for giving you the "go check the FAQ's" answer.
Old Jan 19, 2009 | 03:43 PM
gatsbys's Avatar
well, I changed the actuator-still nothing (in fact I think I made it worse as it used to open and close from the inside-and the problem was that it wouldn't lock and unlock via the key fob or the drivers door-now it doesn't do anything!...aghh!!!)
Old Jan 19, 2009 | 04:01 PM
Brutal's Avatar
i forgot on xtypes the module for the doors is the body proccessor under dash pass. side. but the actuator still may not have worked on the new door hense no lock feature since the motors go out. as far as not opening from the inside put the cable in the other notch. or make sure you didnt inadvertantly leave it unhooked either the actuator or the inner handle on the door panel. after you fix this, reboot the module by disc battery negative terminal and briefly touch it to the still connected positive to discharge caps. and this will default all modules and might get the body module working the door lock again, or you may have another issue..
Old Jan 19, 2009 | 04:52 PM
gatsbys's Avatar
Thanks for that-I'll try that when I geta chance-when you say passenger side-do you mean on the right side of the car (I'm in the UK so passenger side will be on the left for me!)
Old Jan 19, 2009 | 09:34 PM
jvegas's Avatar
ORIGINAL: McJaguar
ORIGINAL: McJaguar
LOL! i remember someone posted a question about changing the engine oil, and 4 people answered with how to change the TC oil! Someone even put up pictures and about 6 paragraphs on how to do it.... Finally someone read the post correctly and pointed out our mistake. I always think of how confussed the poster must have been.
Old Jan 19, 2009 | 10:19 PM
Brutal's Avatar
ORIGINAL: gatsbys
you know I really wish locations where posted like all other forums I visit, it cuts down on miss communication, and she can be a Bihct....works for issues that are climate related too like cold or heat related.. and I would assume its on the left side opposite driver in the UK
Old Jan 20, 2009 | 09:45 AM
gatsbys's Avatar
When you said diconnect the negative at the battery-then very briefly touch it on the still connected positive terminal-won't this blow something-least of all-won't it damage the battery and possbly the ecu as well??
stanjag
Dec 29, 2024 08:26 PM
hafren
Aug 30, 2023 03:42 PM
MarathonJohn
Sep 3, 2015 07:59 PM
Aranon
Sep 3, 2015 07:56 PM
frankc
Sep 1, 2015 04:41 AM
