X Type Problem Code P1638
Old Apr 5, 2011 | 12:52 PM
Ken's Avatar
Ken
Update: I decided to check if the fuse for that oxygen sensor heater was blown and it turned out to be MISSING. I put in a new fuse and I feel like the car is running like new. I will make sure to confirm by getting the codes checked again, but I'm sure that was the problem. About how long do you think before code 1000 clears itself?
Old Apr 5, 2011 | 02:35 PM
Thermo's Avatar
Veteran: Navy
Ken, the fuse for the O2 sensor heater? What fuse did you find missing? The O2 sensors are powered directly off of the ECM. There is no fuse there that I am aware of (need to double check the diagrams, but am 99.9% sure).
Old Apr 11, 2011 | 09:10 AM
jaguarNeWb's Avatar
Default Engine code problem
sorry to jack the thread but im a new jaguar owner and my check engine light came it and the code was P0430 i was told to replace my cat and my bank 2 O2 sensosr, will that correct the CEL ?
Old Apr 11, 2011 | 05:33 PM
Thermo's Avatar
Veteran: Navy
NeWb, first replace the O2 sensor and see how things go then. I bet you will find that replacing only the O2 sensor will correct your situation. For a cat to go bad in you Kitty is a very rare thing. Also, check on the price of a new cat for the Kitty. I bet you will be really willing just to replace the O2 sensor and see.
Old Apr 12, 2011 | 09:19 AM
Ken's Avatar
Ken
Yes, the fuse for the heater was missing. I have felt a difference since replacing it but the code is still present, so it seems that did not fix the problem entirely. In the end, I may just need to get the new sensor. I read your description on how to replace it but I'm still not sure how to go about it. Is there somewhere that describes this procedure in detail with maybe some pictures showing exactly where to look?
Old Oct 8, 2011 | 10:42 PM
queensnewbie's Avatar
Thermo, I am rehashing old issues here, but in my long story with the OBD II reader not working I had codes pulled from the dealer of p1638 & p1637. The OBD II reader get "no link" and these codes indicate a CAN LINK errors. I also noticed that my lights dash flicker from time to time when illuminated at night. I am guessing the OBD II reader doesn't read because of a faulty connection between it and the instrument cluster. Do you think any of this is related and how would I check the IC if you think so? thanks so much again
stanjag
Dec 29, 2024 08:26 PM
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
