X-Type Rear Wheel Bearing Replacement
Old Jan 22, 2014 | 01:58 PM
David Souder's Avatar
Default X-Type Rear Wheel Bearing Replacement
I have a '05 X-Type 2.5 manual tranny. What tools will I need to remove and install the Rear Wheel Bearings? And should I replace the entire hub assembly or is there a less expensive way to go?
Old Jan 22, 2014 | 02:50 PM
Welcome to the forum David,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 22, 2014 | 04:00 PM
Thank you Graham
Old Jan 23, 2014 | 07:35 AM
faltwen's Avatar
Complete hub assembly is the way to go. It is not cost effective to attempt stripping the old assembly.
Once the wheel, caliper and disc are off, you'll need a hub puller to get the unit off the driveshaft and a good set of torx sockets to undo the 4 bolts holding it in place. Maybe different in the USA but when I did mine the bolts were well rusted and due to rust issues Jaguar have actually changed the design from internal torx to external torx. You will need 4 new bolts although my kit came with a set.
Also a big socket (possibly 36mm) to undo the hub nut.
Old Jan 23, 2014 | 05:03 PM
suprasix30's Avatar
Hi just did mine after a collision with a kurb I found absolutely dosing them with a good penotrating oil G85 is a good one better than Wd40, make sure ur torx bit fits tight and bfore attempting to undo give the end of the bit a sharp few taps with a hammer, this help displace the corrosion. If the torx bit does slip use an allan key bit, but one that you will have to drive in with force. Thats how I had to do mine in the end hope helps good luck
Old Jan 24, 2014 | 01:24 PM
Thank you for the info guys!
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
rvdz
Dec 7, 2019 06:42 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
JaguarXKR
Sep 6, 2015 11:47 AM
