X type throttle
Old May 19, 2008 | 08:01 PM
ibjags's Avatar
Default RE: X type throttle
cb
Old May 19, 2008 | 08:02 PM
Thermo's Avatar
Veteran: Navy
eurotec, first, do you have a 2004 or a 2004.25 X-type? There are slight differences between the two. Assuming you have a 2004, if you open up the hood, open up the power distribution/relay box(above the driver's side wheel well) and look at it. On the edge nearest the bumper (towards the engine), you will see 3 large relays in the shape of an "L". On the inside of this "L", there will be a smaller relay, that is your throttle motor relay. The relay is known as "R11".
If you have a 2004.25 model, look in the back of your car at the fuse box back there (passenger side). If you look at one end of it, there will be a large cover. Remove the cover, you will find 4 relays back there (R7, R8, R9, and R10), R7 is the throttle motor relay.
Hope this helps. If you need any more info, just hollar.
Chris "Thermo" Coleman
Old Mar 21, 2026 | 01:53 PM
BT123's Avatar
first time poster long time follower of your advice Thermo (first car and since has been an x type propped up on your knowledge). from my understanding the r7-r10 relays are non serviceable pcbs built into the passenger side fuse box. if these are fixable or swappable this would be great to know.
Old Mar 21, 2026 | 06:54 PM
Dell Gailey's Avatar
are r7to r10 fuses replaceable on a " jaguar X-Type"
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAAB zenr0AAABJklEQVR4Ae2WpVaFQRSFcaeS4QVwIjTiLbgk7D1w9 xeg4FQcOu6acHeXtNnDmsFd7in/WetLI+f7dbYDAFEsAUvgoeAQ5k5iSQFpIH1kkMyQFXJMTsgpwT uc6jlHes2M3qNP71mge7g76DLNg8gygZ1QckGmuSdZJ7Azq8RD CSQTCJGgBCoFBWqVQLegQJcSmPnWIr9oICMXcIr4C4FJJbD9rU X+NtzX+CIQlfVbgS0lcP4jAVNt/UCA7acCZ0oAPxfQdXMLFNUBvpHflvgbAVM7h0B6zrfeD3kB+Uc g/xLKf4biPyLJX3GH9GFUogRSBQUSTSBZEwskQpFs1USyl6E0gRS RJtJPhsnci1B69oVQeqzXzOo9+kmj3juBeDw2BkSxBCyBO+9s0 3HRLVCoAAAAAElFTkSuQmCC[/img]Yes, the R7 to R10 relays (often referred to as fuses in some contexts) in the Jaguar X-Type engine bay fuse box are replaceable, though they are usually plug-in relays rather than standard blade fuses
. These relays control various electrical systems, and accessing them requires removing the lid of the fuse box, which may require releasing clips with a screwdriver.
Example =
Old Mar 21, 2026 | 10:19 PM
BT123's Avatar
should have clarified I have the 2004.25 wiring on my vehicle so my throttle control relay is in the passenger fuse box. On the wiring diagram it states they are non serviceable pcb relays
Old Mar 30, 2026 | 07:59 AM
iownme's Avatar
bear in mind ai is OFTEN very WRONG and can lead you up the garden path to a slap in the face
Old Mar 30, 2026 | 05:25 PM
dh53's Avatar
My Jag Electrical Guide for VIN: E19616 on says R7 to R10 are non-serviceable, they are built in to the fusebox PCB. The guide calls out R7 as the Throttle Motor Relay for the 2.5L and the 3.0L. If you have a 2.0L or a 2.2L or your VIN is before E19616 none of this applies. I guess?
Bottom line, if your Throttle Motor Relay is built in to the fusebox PCB and you have traced your fault to that relay you will probably need to get a fusebox from a junkyard, Jag parts specialist, or Jag dealer.
Old Mar 30, 2026 | 05:59 PM
dh53's Avatar
OCJoeR
Feb 6, 2025 03:30 PM
ZephyrWarrior
Nov 18, 2023 05:06 PM
Ilkka313
Aug 26, 2023 02:46 AM
dynoguy
Jul 26, 2015 07:00 PM
TinyDancer91991
Jul 31, 2013 04:46 AM
