Xtype 2002 window help
Old Aug 16, 2022 | 03:04 AM
Zoombo's Avatar
Default Xtype 2002 window help
Hi i have a completely dead driver window that gets no response. Both right side windows work perfect, back left is mostly working sometimes it wont go up easily but i think its something with the track and will deal with later. Looking to first replace the fuses for them and wondering which fuse number they are as i dont have a manual for the car. Did some research on here and saw both 50 and 11 nots sure if those are correct and looking for some help. Would like to try this first and hopefully wont have to do the disconnecting batter method. Thank you
Old Aug 16, 2022 | 01:48 PM
Dell Gailey's Avatar
X Type 2001 to 2003 (& early 2004)
your problem is most likely not the fuse as you said the rear does move.
Old Aug 16, 2022 | 11:34 PM
Zoombo's Avatar
Thanks i check you are right the fuses are fine. Any ideas on what to check next?
Old Aug 17, 2022 | 01:49 AM
Most likely the regulator. This can be a minor as chuffed wiring or major the unit died. It necessitates door card removal and inspection. Rarely is this posted by a forum guru, Thermo =
For those with issues on the right windows, odds are, you problem lies in the driver's door switches. If they become loose, the switch does function like it should and results in the window not getting properly configured. If you pull off the driver's door panel and then get the switch in the proper position, all will work better. Kinda like you can get it to work a bit better by lifting and pulling the switch sideways towards the outside (as I recall) as you lift it to make it go up with the 1 touch feature.
1cigar
Oct 5, 2021 11:36 PM
hak
Oct 13, 2019 10:46 AM
qwiketz
Jan 30, 2010 09:14 AM
gbourck
Apr 30, 2009 05:13 PM
