Interior door handle fixed for $2
Old Oct 5, 2009 | 11:30 PM
cooke's Avatar
Default Interior door handle fixed for $2
When an interior door release handle breaks its because the cord that’s attached to the handle breaks off at the end. At the end of the door release cord is a ball end that serves as a cable stop. When the ball breaks it the same as the knot breaking on a piece of thread that goes through a needle. To fix the cord with out having to purchase an entire handle and cord set-up; you buy an independent cable end stop shown in the picture. They cost about $2, it's just like threading the needle, this little maneuver will save $150. I hope this helps.
Old Jul 13, 2011 | 04:38 PM
imagineaudio's Avatar
Thanks for this!
My driver's side interior handle just broke this morning. Haven't pulled it off yet, but this is helpful either way
Old Jul 13, 2011 | 08:27 PM
RBA's Avatar
RBA
Sounds like a great suggestion and solution, too bad my access is denied for being a noob.
Old Jul 14, 2011 | 05:59 AM
biffta's Avatar
I posted something on this sometime back as I'd repaired both my door handle cable mechanisms.
As for the cable stop you can also use a small electric cable connector block. These are very cheap and for those who don't know what I'm talking about, it's the small block in which you can insert 2 or more electric wires and screw down to secure them. If you just want to use the metal bit in the centre then just cut away the plastic outer insulating material.
Old Jul 18, 2011 | 09:51 PM
Well I gave it a go today with the cable stop pictured by OP.
I found that when I got the cable seated and the handle operating, it blocked the locking mechanism
How did you work around this?
99xk8guy
Sep 29, 2025 10:51 PM
Dz1rfj
Jul 17, 2018 10:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
AL NZ
Sep 4, 2015 08:39 PM
