XE ( X760 ) 2015 -
2017 Jaguar XE Coolant Leak
Old Dec 12, 2025 | 08:52 AM
DylanHen1970's Avatar
Default 2017 Jaguar XE Coolant Leak
Im not overheating heater blows cold and my resvoir keeps losing coolant. I was driving had red low coolant message pop up i pulled over checked resvoir was empty. I went to closest shop bought whole bottle and refilled resvoir. I have driven maybe 30 miles cause I got rest way home and then to closest gas station one day and my resvoir is almost empty again. There is coolant from one side of engine to the other no check engine light hasn't even warmed up much less overheated at all. Anybody know where to start? Maybe hoses and clamps to check? Idk I need help
Old Dec 13, 2025 | 05:36 AM
DJS's Avatar
DJS
Which engine do you have? The V6 has known issues with plastic cooling pipes failing. Many threads about it (and metal replacement parts) in the F-type forum - same engine.
Old Dec 13, 2025 | 05:56 PM
dangoesfast's Avatar
Find the puddle of coolant, look nearby for where it's coming from, that's really all the advice anyone can give you on fairly limited info. Fill the reservoir, start the engine, look for a stream of coolant.
The plastic pipes on the 3.0 are well known for exploding, but it could be one of a dozen pipes or seals or junctions or whatever. Coolant leaks are the kind of problem you just have to look and look and look more until you figure out where it's coming from, there's no secret or anything you just gotta find the leak.
Old Dec 18, 2025 | 08:40 AM
Haalex's Avatar
The expansion tank is quite large on these cars, so that's a high consumption you're talking about. . I guess you should see coolant pooling under the car, and go back to the leak from there.
Ale223
XE ( X760 )
Oct 27, 2025 11:03 PM
XJ8Johnny
XE ( X760 )
Aug 26, 2024 05:47 PM
ericf813
XE ( X760 )
May 28, 2024 09:45 AM
stuhillman
XE ( X760 )
Dec 21, 2020 04:55 AM
