XE ( X760 ) 2015 -
Do XF wheels fit the XE?
Old Feb 21, 2018 | 10:53 AM
joejob's Avatar
Default Do XF wheels fit the XE?
Hi guys, i'm shopping for bigger wheels for my 2017 XE 25t and found a great used set that came off an XF. They're 19" and I know they're a bit wider. Has anyone ever used this setup?
Old Feb 22, 2018 | 11:01 PM
alphakinase's Avatar
They will definitely bolt on. We would need more info on the wheels in consideration to tell you if they'd actually fit in the wheel well and around the brakes...
Old Feb 16, 2022 | 08:33 PM
GaguarGuy's Avatar
Default Wheel swap
Generally, yes. Although some Jaguars have staggered wheel setups that may be less swappable.
Bolt patterns are consistent, so wheel diameter, width, and offset are the primary concerns. You can check these thru the dealer or a site like Tirerack.com
tsantsa
XE ( X760 )
Feb 16, 2022 08:30 PM
Prange
XE ( X760 )
Jul 14, 2018 08:17 AM
XE-LV
US Western
Oct 23, 2017 01:00 AM
HerrLorenzen
XF (X260)
May 26, 2017 05:25 PM
mosesbotbol
XE ( X760 )
Aug 29, 2016 02:39 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
