XE ( X760 ) 2015 -
Engine Noise
Old Jan 18, 2017 | 08:26 AM
RaffiNJ's Avatar
Default Engine Noise
Is anyone else getting a slight whiny noise when starting up the car ? I heard it a couple of other times and decided to look into it this morning. When I start the car I can hear from the inside this slight whiny/hissy noise coming from engine. I opened up the hood and besides the regular engine noise there is another type of noise coming out. Very hard to say what it sounds like but its almost like a lose timing belt without the squeakiness, more like it wasn't lubed properly and its rubbing just the wrong way? it is not very loud. I figured I will check if its still there when I get to work and I think it was gone but the garage has so much echo that I am really not certain. Never had a supercharger in the car so not sure if this maybe something normal for these types of engines? for all I know it maybe a blower of some kind, its just that there 2 distinctive noises coming out of the engine for sure.
RaffiNJ's Avatar
If no one knows I will try to record this after work (if it returns) or tomorrow morning, not really sure if its loud enough to record on my phone though.
Old Jan 18, 2017 | 08:54 AM
BigCat09's Avatar
It could be the cold start injection which goes away after warm up.
Old Jan 18, 2017 | 09:20 AM
RaffiNJ's Avatar
thanks BigCat, do you hear anything in yours? btw were you a member of any other car forums before, hummer for instance? I keep thinking I know your alias from somewhere.
Old Jan 18, 2017 | 02:46 PM
BigCat09's Avatar
YEs, mine makes the sound.
No not me, just here on this forum.
Old Jan 22, 2017 | 05:34 PM
alphakinase's Avatar
Mine does this as well, think its normal. It's also been described in the V6 F-type
