XE ( X760 ) 2015 -
Glovebox Removal
Old May 20, 2021 | 12:12 PM
Radium's Avatar
Exclamation Glovebox Removal
Hi all, Im trying to remove the glovebox from my car to install a new headunit. Im finding it really difficult to remove that plastic undertray underneath the glovebox. Here is a reference image I found. Would love it if someone can guide me through removing it.
Old May 26, 2021 | 06:13 AM
Rummy636's Avatar
Three plastic rivets with a panel tool. Comes out really easy.
Old Jun 3, 2021 | 04:39 PM
Radium's Avatar
Turns out you dont need to remove the glove box after all. If anyone faces this again. All you gotta do is remove the cover right under the unit with the power button. Once that's done, you will feel the back of the unit from there. It is only held in by clips so you can just pull it out. The clips are quite strong so you gotta use a but of force.
Old Jun 13, 2024 | 04:00 AM
Dioni's Avatar
Default Glove box undercover
Thanks, this is a great forum.
By the way I am interested in that blue piece. Could some one tell me de name of this piece or the reference number?
Thanks a lot.
Old Jun 14, 2024 | 03:52 PM
2018XF25T's Avatar
On my XF, you have to take the glove compartment out in order to get access to the cabin air filter. While you are it, look if the cabin filter is in that area somewher and if you see it, replace with a new one.
Old Jul 28, 2024 | 10:29 AM
Docmonte's Avatar
That is a great idea. It would be a shame to remove the glove box and not change the cabin filter since it is staring you right in the eye. Indeed, the XE cabin filter is right there behind the glove box.
As an aside, the dealer wanted ~ $300.00 to change mine but with the help of the forum and a you tube video, it was a breeze. The only ironic thing is that when I went to remove that first plastic cover, "blue piece" posted by Radium, I realized that mine was not even there. It must have been busted off and discarded by the last genius that couldn't figure out how to remove it.
If someone does have the part number, I would replace men as well...
Shadow993
Dec 21, 2016 08:09 AM
anthawk
Jun 12, 2016 12:20 PM
Ajohnsonnefn
May 16, 2013 06:47 AM
GhostriderXKR08
Mar 15, 2009 06:59 PM
morales8416
Sep 25, 2008 04:11 PM
