XE ( X760 ) 2015 -
Ingenium engines top mounted oil filter removal
Old Jan 27, 2019 | 09:53 AM
chrisjp's Avatar
Default Ingenium engines top mounted oil filter removal
The Ingenium engines have top mounted oil filters which just require the plastic cap to be unscrewed to remove the filter element. However this element is attached in some way to the plastic cap and apparently won't just pull off. The new element is identical at each end and doesn't appear to have any sort of clip built into it. Does anyone know how to remove the element from the plastic cap?
Old Apr 3, 2019 | 06:23 AM
chrisjp's Avatar
Answering my own question (!), I've found that the oil filter does just pull off the cap - but it needs quite a sharp pull to disengage it. The new oil filter just pushes onto the cap until it clicks into place.
al_roethlisberger
Feb 7, 2017 07:59 AM
pcbrew
XE ( X760 )
Sep 15, 2016 07:03 PM
Flying Finn
30
Dec 20, 2010 08:14 AM
