XE ( X760 ) 2015 -
Knocking sound - XE diesel automatic
Old Jun 23, 2025 | 12:50 PM
Domen's Avatar
Default Knocking sound - XE diesel automatic
Hello everyone, new member here.
I need help identifying an issue on my XE 2.0 diesel (180PS), automatic trans.
After a drive, when I stop the car, I can hear a knocking sound coming from the left hand side of the car under the hood. It sounds like it's coming from somewhere behind the front left wheel. The sound is only present when car is stationary or at very low speed. I have also noticed that if the engine is on and the car is stationary, the noise changes as I flip through gears. For example, the clunking sound is very noticeable when gearbox is in reverse, slightly less noticeable when in neutral and not present at all when in drive. I have attached an audio file so you can listen to it.
Any ideas as to what the issue might be would be greatly appreciated.
Thank you!
File Type: mp3
Old Jul 12, 2025 | 02:01 PM
Domen's Avatar
Turns out the sound is coming from an engine mount and it will need replacing. Hope this helps anyone.
Old Jul 14, 2025 | 05:01 PM
Fraser Mitchell's Avatar
It's a common fault, I believe. Your main problem may be actually obtaining a replacement.
Old Jul 15, 2025 | 08:05 AM
Domen's Avatar
Yeah, a failed engine mount is kinda disappointing at only 68k miles. Hope the other one holds up. The autoshop actually had no problem getting the original replacement part, it was expensive though.
ryan.kent221968
XE ( X760 )
Aug 17, 2021 03:53 AM
Leviathan123
XE ( X760 )
Feb 6, 2021 01:12 PM
Jag7
XE ( X760 )
May 11, 2018 02:31 PM
JimC64
XE ( X760 )
30
Jun 29, 2017 01:56 AM
JimC64
Jaguar Press release
May 11, 2015 07:33 PM
