XE ( X760 ) 2015 -
Rattel in D Mode at idle when outside below 2 °C and engine / car cold
Old Feb 21, 2018 | 06:15 AM
Xephil's Avatar
Default Rattel in D Mode at idle when outside below 2 °C and engine / car cold
Hello,
this is my first post; probably as with many of you, because of a rattle :-)
Well, this rattle noise, presumably from the inside behind the glove compartement is making me insane. I already checked the enging compartement an couldn´t find anything what could cause the rattle. Neither did I find anythin in the inside of the car. A pillars, glove compartement (itself). I already read probably all of the rattle-threads; nothing which really fits.
I occurs after engine start, in D, engine at idle (but cold). In case its warmer outside (above let´s say 4 or 5 °C) you won´t hear anything. So it must be temperature dependent. You can hear it sometime driving long winding curces at slow speed oder even after engine is warm, after lifting the brake pedal in the first moment of acceleration.
Has anyone an idea, what could cause this constant rattle (sounds like "drrrrrrrrrr" "drrrrrrrrrr"); probably a screw, clip or two plastic parts, most probably from the area where A-Pillar, Dashboard an the small round speaker cover meet.
Thanks in advance.
PS: one or two more weeks and I'll take a hammer and demolish the entire car :-)
madijag
Jan 10, 2018 11:18 AM
reb1999
Mar 22, 2016 08:10 AM
davepsj
Photography
Mar 3, 2016 11:17 AM
NorJag
Feb 2, 2015 12:33 PM
OldSpiceGK
Jan 30, 2015 01:02 PM
