XE ( X760 ) 2015 -
Removing coolant with pump before replacing pipes?
Old May 23, 2025 | 06:08 AM
Dave5150's Avatar
Default Removing coolant with pump before replacing pipes?
Hi gang, I’ve ordered the metal coolant pipe replacement kit from Euro Amp and even though the process is well-documented, I had a couple questions. First, instead of pulling the cover off the bottom and draining the coolant, would it be fine to just pump it out of the reservoir? If so, could I add the same coolant back in one I’m done? I have the tools and kit, but anything else I’d need to order before tackling it?
Old May 23, 2025 | 07:05 AM
DJS's Avatar
DJS
I’d suggest posting your question in this big thread on the F-type forum, lots more traffic than the XE forum. Same engine.
https://www.jaguarforums.com/forum/f...inally-258775/
Old May 23, 2025 | 07:08 AM
Dave5150's Avatar
Good call, I'll try that. Thanks!
Gearhead01
Dec 26, 2025 09:18 AM
bocatrip
Dec 24, 2023 05:35 PM
HippoCow
XE ( X760 )
Jul 19, 2023 09:02 PM
Gasman2
Jul 10, 2023 10:07 AM
SinF
Sep 2, 2017 01:23 PM
