XE ( X760 ) 2015 -
When does the Parking brake set itself
Old May 28, 2020 | 03:14 PM
cmking26's Avatar
Default When does the Parking brake set itself
I've noticed a couple times now, I have gotten in my car and started it to leave but the parking brake was set and I did not set it. Does the XE sometimes set this on its own for some reason?
Old May 28, 2020 | 03:47 PM
The EPB should set automatically when the vehicle is in park.
Old May 28, 2020 | 04:34 PM
cmking26's Avatar
Okay, so it automatically comes on when you put the vehicle in park? Should it automatically shut off when I start the car and select Drive? Or do I always have to press the brake and push the EPB switch?
Old May 28, 2020 | 05:30 PM
No you just put it in drive and go. If you activate the EPB when you are in drive at a light for example it will release automatically when you push the throttle to pull away.
Old May 28, 2020 | 07:17 PM
cmking26's Avatar
Okay, that makes sense. I was seeing PARK lit up and thought I had to manually release it by pressing the button. So next time I drive I'll just tap the throttle, it should shut off, and away I go. Thanks for the help.
blackphoto5
Aug 6, 2020 04:39 AM
Pompey
May 8, 2020 01:19 AM
pelle
Jan 25, 2018 09:16 AM
Adam Lueb
Jul 19, 2016 12:55 PM
millenia man
Jan 29, 2011 05:06 PM
