XE ( X760 ) 2015 -
XE rotor sizes
Old May 26, 2018 | 09:04 AM
Cincy XE-RS's Avatar
Default XE rotor sizes
Does anyone know a source that we can figure out our rotor size per sub-model? I am looking at getting cross drilled rotors and so far I have not found anyone that does them other than custom.
Looking across the net I have seen 4 different sizes for front rotors throughout the XE lines, two within the R-Sport line.
I am interest in the front and rear sizes although there is less of a debate on the rear.
I put my question generically in case others are curious but I am specifically looking for a 2017 35t R-sport
front rotor search so far has turned up all the below for my year/model
316mm
325mm
350mm
380mm
rear
300mm
316mm
325mm
Thank you
Old May 26, 2018 | 03:07 PM
DJS's Avatar
DJS
Interestingly, the 2018 XE brochure doesn't mention brake sizes anywhere. Strange.
Old May 27, 2018 | 11:52 PM
carpenter75's Avatar
I posted this in a different thread, but here are the sizes at least in the US.
Originally Posted by carpenter75
Those here in the US (I assume other markets) with the 2017 and 2018 35T have the same 13.8 inch front (350mm) and 12.8 inch rear (325mm) brakes as the S. The 35T is now gone from the lineup, however.
The 30T and 25T has 12.8/12.8 inch and the 20D diesel has 12.4/11.8
Old May 28, 2018 | 02:58 PM
Robman25's Avatar
Take a wheel off and measure?
jeremiahjaguar
Jan 17, 2013 11:13 PM
teams811
Audio/Visual Electronics
Feb 14, 2008 06:14 PM
teams811
Feb 12, 2008 10:30 AM
jagxtypeboy
Jan 19, 2008 06:52 PM
geminiblinds
Oct 24, 2007 09:45 AM
