XF (X260) 2015 onwards
12v power tap, best source?
Old Oct 23, 2017 | 03:21 PM
Macbeemer's Avatar
Default 12v power tap, best source?
2015 Jaguar XF: where's the best 12v tap under the hood for an aftermarket accessory? I want to hook up an ultrasonic mouse repeller! I think the best trick would be to wire up a dummy fuse and hit an open bay in the fuse box, but I'm all ears if you have a better idea, or experience in the matter. Thanks in advance.
Old Oct 24, 2017 | 01:57 PM
ololly's Avatar
Why wouldn't you install a stationary ultrasonic mouse repeller in your garage? This will eliminate the possibility of battery discharge. Unless you want to repel mice from approaching the moving vehicle
Old Oct 24, 2017 | 02:32 PM
Macbeemer's Avatar
There is an ultrasonic mouse repeller in the garage. The garage holds a lot of other vehicles, and the Jaguar is low man on the totem pole, so it lives outside. The draw for the ant-pest thing is minimal, 20 mA, so I'm sure it will be fine. Do you have an answer to contribute?
Old Oct 24, 2017 | 03:38 PM
ololly's Avatar
I do. Since the battery is in the trunk I'd tap it to a jumping connection. You know, the one you clip jumpers cables to.
But that's just my 2c. The easier the better.
Old Oct 24, 2017 | 06:00 PM
Macbeemer's Avatar
I will be locating this device beneath the hood of the car, to protect the wiring in the engine compartment. Therefore, I will tap a line closer to where it's needed.
Old Oct 24, 2017 | 08:13 PM
ololly's Avatar
Jumping connectors ARE beneath the hood of a car. Battery is in the trunk, but the connector is under the hood.
Old Oct 26, 2017 | 11:08 AM
Macbeemer's Avatar
No battery contacts under the hood on this model/year. I found a good spot in the fuse box.
