XF (X260) 2015 onwards
2 post lifting points? Xfs 3.0 diesel
Old Nov 10, 2024 | 06:49 AM
Helpaguyout's Avatar
Default 2 post lifting points? Xfs 3.0 diesel
Hi, does anyone know the lifting points on the x260 please? Should I lift from inside where the arrows are marked on the sils?
thanks
Old Nov 10, 2024 | 07:18 AM
User 42324's Avatar
Those arrows are for the supplied jack. I don't have a pic on my phone, but a quick internet search will turn up a diagram or two.
Old Nov 10, 2024 | 08:37 AM
clubairth1's Avatar
Community Influencer
From the workshop manual.
The lifting points.
Here are the support points after you get it jacked up as you never work under anything unless it is supported and NOT on a jack!
They are very close together so you might have some trouble getting your jack stands to fit.
I have an XJ and those spots are by the arrows cast into the plastic skirt of the car. On the XF I am not sure?
Interesting comment about the factory jack that I had not seen before either?
Old Nov 10, 2024 | 08:57 AM
Thankyou, yeah I'm using a 2 post lift on Tuesday that I've hired and don't want to bend the car thats all
Old Nov 10, 2024 | 03:44 PM
clubairth1's Avatar
One error I made? My answer if from the Gen I XF manual? Don't have a manual for the later Gen II like you have.
Cars are still pretty close but Jaguar may have changed things?
Anybody have the Gen II instructions?
Old Nov 12, 2024 | 07:43 AM
Hi all,
Ive just had the car on the 2 post lift, lift points are easy there straight behind the markers on the sill. If it helps anyone out anyday car and van rentals in heanor are renting a workshop and 2 post lift which is perfect for the diy jobs.
Underside of xfs x260
Old Nov 14, 2024 | 03:56 PM
richardsjags's Avatar
I have a 2 post hoist for my Jags.
Be careful with the XF.
You might find the arm of the hoist hits the plastic trim under the doors before it takes up the jacking points.
I had to make wooden spacers between the pad on the end of the arm and the jacking points to prevent that.
You will see what I mean when you try it.
Old Nov 14, 2024 | 04:48 PM
Follow up.
I found one of the hoist aid pads I made. Photo attached.
You need a hardwood, pine might be a bit soft. It is 35mm thick.
The 2 screws help locate the side of the seam where the jacking point is.
Not much space under there when trying to get it in place.
The groove in the pad is created from the seam resting on it.
XF hoist aid
XF hoist aid
Old Nov 15, 2024 | 08:54 AM
clubairth1's Avatar
Good idea!
I also use what's called Pinch Weld adapters on my new two post lift.
They are made of rubber.
The same idea just made of rubber.
zimt
XF (X260)
Nov 6, 2022 03:23 PM
jean HJ
Jan 22, 2022 12:37 AM
nodrog3
Diesel variants - All models
Apr 7, 2021 08:51 PM
scrappydoo
XF (X260)
Apr 30, 2020 10:05 AM
Mr5000
Oct 10, 2016 09:32 AM
