XF (X260) 2015 onwards
2009 XF Hood Won't Latch Closed
Old Oct 18, 2019 | 10:56 PM
Dallas Rockford's Avatar
Default 2009 XF Hood Won't Latch Closed
The hood always seemed to need a bit of convincing, but now it won't latch shut on the left and right sides. The center latch, the least important - is functioning properly.
I've tried a screwdriver to loosen the spring of either side,I've added WD40 lubricant, I've tried playing with the cord via the latch handle / bonnet release latch inside the car - all to no avail.
I've tried to adjust the left and right rubber stopper/posts heights and also tried to adjust the upper hood brackets. Nothing solves it....
With the great challenges there are designing a car, it is absolutely stunning that this minor but important detail is so poorly designed.
If anyone has any ideas, please help - otherwise I think I need to dismantle the entire front end, replace both the left and right latches and the cable. What a g*dd*mn joke!!!!
Thank you
Old Oct 19, 2019 | 10:05 AM
XFJoe's Avatar
This is the 2016 and newer forum.
Try posting here: https://www.jaguarforums.com/forum/xf-xfr-x250-44/
Atlastajag1
Nov 6, 2018 11:13 AM
mikebaker3
Jul 21, 2016 01:22 PM
oldpunk
Mar 28, 2014 03:39 PM
OxfordTheCat
May 20, 2013 06:17 PM
xk82006
Sep 8, 2012 11:46 PM
