XF (X260) 2015 onwards
2010 XF leaking in Kansas
Old Jul 14, 2020 | 02:14 PM
Conrad in kansas's Avatar
Default 2010 XF leaking in Kansas
My water pump is leaking on my Jag I have downloaded the service manual for some needed information I have the pump removed but needed service manual to continue
Old Aug 13, 2020 | 09:48 PM
Default Leaking in Kansas ??
I remove the water pump. And purchased all the new parts and gaskets. I tried to clean up where the antifreeze had leaked onto the valley but I'm not sure if the antifreeze runs clear to the back of the engine or is just contained towards the front I rinsed it out and use my Shop-Vac with a makeshift funnel
Old Aug 13, 2020 | 10:09 PM
NBCat's Avatar
How many kilometres/miles on the vehicle?
You may also want to replace the water outlet pipes, thermostat and heater pipe as they're known failure points on the AJ133.
Old Aug 13, 2020 | 10:38 PM
I remove the water pump. And purchased all the new parts and gaskets. I tried to clean up where the antifreeze had leaked onto the valley but I'm not sure if the antifreeze runs clear to the back of the engine or is just contained towards the front I rinsed it out and use my Shop-Vac with a makeshift funnel zzz
Old Aug 14, 2020 | 08:07 AM
F1Virginia's Avatar
Nice work & pics!
That pump looks a beauty but would like a pic of the old too.
I trust the new pump is AJ813909 (newest version)?
Can't quite read the bag sticker.
You get your new coolant ready?
Let us know if you also replace the 3 pipes suggested here.
​​​​​​​Best Wishes for a speedy recovery..
Old Aug 14, 2020 | 11:29 AM
Lotibob's Avatar
Default Kansa water pump
Conrad.....if you need to order the replacement pipes, suggest you contact jagoutlet.com and ask for Terry. Friendly pricing on new, used Jag parts.
Rock Chalk Bob in Overland Park (E type, XF owner....Heart of America Jag Club).
Kaeghl
Jan 8, 2016 12:05 PM
Jaiello21
Sep 14, 2015 09:42 PM
Rique
Dec 25, 2011 06:40 AM
nickdentist
Dec 6, 2011 11:35 AM
