XF (X260) 2015 onwards
2017 XF-S 3.0 Supercharged Poor Ride Quality
Old Jul 22, 2024 | 12:27 AM
Jason1701's Avatar
Default 2017 XF-S 3.0 Supercharged Poor Ride Quality
Hi all,
Recently acquired a 2017 XF-S and was interested to see others experience with what I perceive as poor ride quality.
I previously owned a 2016 XF 25T R-sport with adaptive dynamics on 20inch wheels with Michelin tires. My new car has exactly the same setup and tires. My issue is that in comparison, the new car seems so much firmer, with a ride that clunks and bumps over bumps, but also seems to float at high speeds. I've checked the suspension, everything seems in order, with no codes and the car has low mileage - approx 45000 miles. To make sure I had a Jaguar specialist look it over and he also gave it the all clear.
To make matters worse, I recently had a 2017 XE 25T R-sport as a loan car, and the ride was a revelation in comparison to my car. It was supple, wasn't noisy and was generally far more comfortable. I did some reading, and i have heard that the S models in both trims are slightly firmer, however, I can't seem to find any info on springs and damper rates being different.
Could anyone on the forum offer some advice?
cheers
J
Old Jul 23, 2024 | 06:00 PM
mleskovar's Avatar
Originally Posted by Jason1701
Hi all,
cheers
J
I'm assuming you checked all the ride/damper settings and tire pressures.
Old Jul 23, 2024 | 07:16 PM
Jason1701's Avatar
Yes, everything has been checked by myself and a Jaguar technician. Was interested to know of others experiences with the ride of their 'S' models. Took another XFS for a spin yesterday and noticed it had the same inherent firmness as my vehicle... guessing it must be a characteristic of the car as my previous 25T was significantly more compliant.
Old Jul 25, 2024 | 10:12 PM
dennis black's Avatar
20 Year Member
my x250 2015 is so smooth ,better than the XJ
Old Jul 26, 2024 | 10:39 AM
mleskovar's Avatar
Have you tried using the softest and hardest suspension settings to see if there's any difference in feeling? Maybe the adaptive dynamics is stuck in one mode? If you set it up to extremes and toggle between race and normal is their a diffeence?
Kevin93940
XE ( X760 )
25
Dec 2, 2022 11:28 PM
Targa4S
XE ( X760 )
23
Apr 10, 2022 09:43 AM
Gilmore Productions
XE ( X760 )
16
Jun 21, 2020 07:32 PM
A4Skyhawk
XE ( X760 )
Mar 31, 2019 08:29 PM
dabank
XF (X260)
32
Jul 7, 2017 10:24 PM
