XF (X260) 2015 onwards
2024 XF, Shifting Question
Old Jul 11, 2024 | 08:36 PM
Mytwocents's Avatar
Default 2024 XF, Shifting Question
Just bought my first Jaguar a few weeks ago. Took it through the carwash today, the kind that their rollers push you through it. With my previous car, I could just shift to Neutral as I rolled to a stop without braking. When I tried it today with the new XF, it shifted to Reverse or Drive or Sport, but not Neutral. As I shifted back and forth to find Neutral, "HOLD" popped up in the instrument panel apparently telling me I couldn't shift anymore. Can anyone tell me what that HOLD is? What does it mean? What did I do to cause it? How do I get rid of it if it comes up again? Unfortunately, I was one of those idiots that forced them to stop the carwash so I could apply the brake, THEN shift to Neutral. Answers appreciated.
Old Jul 15, 2024 | 01:25 PM
mleskovar's Avatar
Carwash? You take your baby to a CARWASH! Never heard of "HOLD". Sounds like it activated the EPB (Electric Parking Brake) but I don't know. You need to look in the manual for the way to disengage the EPB. Also there's a procedure to disengage the transmission for towing you should be familiar with if you're ever in that situation.
Old Jul 15, 2024 | 04:15 PM
Mytwocents's Avatar
Got through to someone at the dealership who had an partial answer for me. The HOLD is indeed the brake. It's intended to keep the car from rolling or moving when you come to a stop and take your foot off the brake pedal. Yet that function was turned off and no answer as to how it turned itself on.
Also, yes I took it through a carwash. While it's a beautiful car, it's still a car. Thanks for the reply.
Old Jul 15, 2024 | 04:27 PM
mleskovar's Avatar
.... The HOLD is indeed the brake. It's intended to keep the car from rolling or moving when you come to a stop and take your foot off the brake pedal. Yet that function was turned off and no answer as to how it turned itself on......
I had the HOLD function in my last Mercedes and loved it. When Jaguar asked me how to improve on the X260 I said "add a Hold function". So it is there but needs to be turned on I suppose. I wonder why they deleted it.
Old Jul 17, 2024 | 11:28 AM
chrisjp's Avatar
[/QUOTE]Also, yes I took it through a carwash. While it's a beautiful car, it's still a car. Thanks for the reply.[/QUOTE]
Each to his own of course, but you only have to look at rental cars that are routinely put through automatic car washes, to see the paint absolutely covered with fine scratches. Regular use of these will dull the paintwork quite significantly.
If you don't want to manually wash your car, the best alternatives are the hand held jet washes, with a soap brush to get stubborn dirt off if you want it.
Old Jul 30, 2024 | 07:19 PM
aliuser's Avatar
Same happened to me, few car washing staff have no idea of PCM which is in engine area right side below dashboard. I think you asked them to clean engine with water and excessive use of water in that area might have sent water inside PCM. Remove battery connections and remove PCM let it get cleaned by electrician and check for any burns. If this is what happened then rest will let you know.
Old Aug 9, 2024 | 08:47 AM
clubairth1's Avatar
Community Influencer
Again completely wrong!
Please stop posting nonsense!
A car wash is not going cause electrical burns -whatever that is?
DO NOT FOLLOW THE ABOVE ADVICE!!!
Leave the PCM alone!
Old Aug 11, 2024 | 08:23 AM
aliuser's Avatar
Sorry it was not pcm it was ecm which is below dashboard from engine side it was not sealed properly and water went inside which causes car to blink lights vipers and doesn't start. The washing people poured lot of water in that area which went inside ecm and I had to replace and program another ECM.
AdzBo
Aug 5, 2024 01:32 PM
zetrezz
Apr 14, 2023 06:56 AM
Centurion
Jun 16, 2011 03:43 PM
veffremov
May 8, 2010 10:43 PM
