XF (X260) 2015 onwards
Blind Spot Sensor
Old Sep 11, 2022 | 12:18 PM
brownxf2017's Avatar
Default Blind Spot Sensor
I am having a fault with my 2017 XF. After a car park tap right at the senor location (left rear). On every journey the blind spot system works fine and then I get a fault alert on the dash. I then just get a constant light on the wing mirrors. I pulled the sensor and do not see damage. Any troubleshooting thoughts please? Also, if i replace the sensor with new or used will Jaguar have to program? Thank you
Old Sep 14, 2022 | 11:54 PM
Bill400's Avatar
Default get access to SDD
A replacement SOD (side object detection) module will require reprogramming for two reasons:
1. the VIN resides in the module.
2. modules are programmed right or left .
So, new modules are not preprogrammed.
Used modules are programmed incorrectly.
SDD can evaluate the problem with diagnostic codes.
There is a reasonable possibility that reprogramming your existing modules may resolve the problem.
PS: your 2017 BSM/SOD modules communicate alerts to the RV mirrors via CAN. The earlier modules are wired directly.
Let us know what you find.
MKJim
Oct 28, 2020 08:00 AM
Ludovic Card
Jul 2, 2016 09:17 AM
Peperami
Mar 25, 2015 04:35 PM
pnfootitt
Sep 6, 2014 11:19 AM
