XF (X260) 2015 onwards
Connector in trunk
Old Jun 25, 2022 | 07:36 PM
Chadly's Avatar
Default Connector in trunk
Was digging around in my trunk preparing to wire up an aftermarket amp and found this connector under the spare tire. What does this go to? I am guessing it's for the factory subwoofer that my car doesn't have? If it is, can I splice into it for signal to my amp? Thanks for the help!
Old Jun 26, 2022 | 08:50 AM
2018XF25T's Avatar
There is a member here named Dennis Black who could "possibly" identify that.
Have you tried if you get a power on that connector plug when you turn the radio on with a multi-tester or an old school circuit light tester?
I always use circuit test light to identify which power it goes through. It is simple to work with and works well for me. Good luck
djyankees31
Oct 10, 2021 02:17 AM
MikeofBonsall
Dec 7, 2018 01:18 PM
slojotaa
Mar 19, 2016 06:57 PM
FabCat
Sep 26, 2015 12:16 PM
