XF (X260) 2015 onwards
Correct fluid for rear differential? (AWD)
Old Nov 24, 2024 | 03:57 PM
Dave_B_B's Avatar
Default Correct fluid for rear differential? (AWD)
Apologies if this is in an obvious spot somewhere,
Need to do the rear pinion seal. Seal easy enough to obtain, but the fluid spec seems to be a secret.
If I specify BOT 720 or Liqui-Moly, Autohaus and the other specialty outfits say "Not applicable" for the 2016.
Cheers for any pointers.
Old Nov 25, 2024 | 10:56 AM
Dave_B_B's Avatar
OK, bit the bullet and bought some time on Topix.
Castrol BOT 750B for the rear diff.
MrKhacheerio
Mar 10, 2025 03:08 PM
SJ9809
Dec 22, 2021 11:32 PM
Jonnhypl
Oct 12, 2020 06:21 PM
JaguarXKR
Mar 19, 2020 10:11 AM
magicjuan17
May 31, 2013 10:33 AM
