XF (X260) 2015 onwards
Grinding noise front near side wheel
Old May 7, 2022 | 04:05 PM
Jay Christianson's Avatar
Default Grinding noise front near side wheel
I have a jag xf 2011 3.0d. I have a grinding type noise front near side wheel. I have changed wheel bearing, discs and pads but the noise continues. when I take the foot off the gas and the car decelerates. Happens more so after car has warmed up.
What could it be?
Old May 7, 2022 | 10:05 PM
2018XF25T's Avatar
Or it could be the differential unit?
Old May 8, 2022 | 03:18 AM
Thanks. I shall get it looked into… so frustrating…. U have to ask is it worth ripping a car apart for a noise or do I leave it??
Old May 8, 2022 | 12:35 PM
2018XF25T's Avatar
Never ignore something what your car is telling you. It must be fixed right away. My reply to you is one of the many causes of grinding noise under the chassis. It could be a simple fix or an expensive one. In order to pinpoint the problem your car must be raised by a lifter similar to this where the wheels can spin freely or have it check by a mechanic who has comparable equipment such as this. Good luck
TBanks98
Oct 2, 2021 05:05 AM
Kgoudie
Sep 4, 2020 01:24 PM
daphil39
Jul 4, 2020 09:39 AM
ChrisB
May 13, 2011 09:41 PM
