XF (X260) 2015 onwards
Jaguar XF 2017 Infotainment system Issue
Old Apr 12, 2024 | 09:16 AM
Soloazar's Avatar
Default Jaguar XF 2017 Infotainment system Issue
Hi I have a Jaguar XF 2017 version with touch pro infotainment system. And for the past couple of months the infotainment system powers up only when the outside temperature is below 5deg celcius. If the temp is more than 5deg then it won't turn on. Couldn't able to figure out why it's happening so thinking about replacing that with any aftermarket one which is good and have Android auto. If anyone could suggest me a best aftermarket infotainment system which is good
Old Apr 12, 2024 | 12:46 PM
mleskovar's Avatar
This sounds like you have a connection that is bad and changes with temperature.due to flexing of plastic, wires, etc. Replacing it might work but it depends on where the bad connection is. You might just repeat the problem. When it should be "on" poke around the wires and connectors under the dash and fuse boxes. It may just come to life.
erndog
XF (X260)
Dec 25, 2021 09:00 AM
Bahez Barznji
Mar 4, 2021 07:46 AM
yntski
XF (X260)
Oct 20, 2016 10:12 AM
Jaguar Forums Editor
XF (X260)
Oct 15, 2016 09:04 PM
tomas6791
Oct 14, 2016 12:30 PM
