XF (X260) 2015 onwards
A little help with XF
Old Mar 20, 2022 | 09:13 AM
nube's Avatar
Default A little help with XF
Jaguar XF R-sport (supercharged 6 cylinder 340HP)
Jaguar XF S (supercharged 6 cylinder tuned for 380HP)
Is this simply a tuning or are there mechanical differences?
My concern is the added work load on the tuned engine over time.
Old Mar 20, 2022 | 09:24 AM
nube's Avatar
Also if it is just tuning then I assume I can just tune my 340 to 380?
Old Mar 21, 2022 | 04:46 PM
2018XF25T's Avatar
Sorry, there are no replies yet as of now about your question on 340HP & 380HP engines, but if I were you I'll ask the members at the Jaguar F-Type forum. They are in the Jaguar Models (Current), sub-forum F-Type (X152). Maybe you'll get more info on these engines. Good luck~
Old Mar 21, 2022 | 05:12 PM
nube's Avatar
Thanks!
Old Mar 21, 2022 | 07:15 PM
OzXFR's Avatar
Yes, the difference between the 340 and 380 PS versions of the AJ126 is entirely the tune, regardless of which JLR model the engine is used in.
Even the "tuned" 380 PS version is under-stressed so no added workload to worry about.
Also remember that for a couple of years (2018-2019 IIRC) there was a factory 400 PS version available in the F-Type known as the 400 Sport.
The engine in my F-Type started off as the 380 PS version (ie F-Type V6S) which I then tuned to 412 hp with a "tune only" then a year after that I added a larger crank pulley and tune to take it to 450 hp. That was four years ago now and it has never missed a beat and has given me zero problems.
The same tuner (Velocity AP) now has a 470 hp pulleys and tune package for sale, the extra 20 hp coming from a new improved and smaller SC pulley and associated tune on top of the larger crank pulley.
And it's not really about the maximum hp, the big change is the massive increase in torque especially "under the curve" which improves mid-range response and drivability no end.
Last but not least no JLR dealership will ever tune your 340 PS version to 380 PS (or more), in theory they could but in practice they are forbidden to do so and are prevented from doing so. There are some privateers out there with the SDD equipment and knowledge who in theory could apply the 380 PS tune to older models but I'm not aware of any having the factory 380 PS tune to do this.
crashxx
Feb 18, 2022 01:15 PM
Bill400
General Tech Help
Oct 31, 2021 10:25 AM
tdellaringa
May 15, 2021 07:13 AM
Geoff_C
Mar 12, 2020 10:38 AM
roccomx5
Jan 30, 2014 09:07 AM
